May be a problem with the logic board?
Hi guys!!
I have a problem with meu iPhone 6. I Turn on the iPhone and the logo appears, with low brightness, and than power off! I replace de LCD but problem persist.
この質問は役に立ちましたか?
Hi guys!!
この質問は役に立ちましたか?
What happened to the phone prior to this issue; was it dropped or damaged, repaired or came into contact with water?
You could have a battery problem or a logic board problem (you already ruled out the screen). Changing the battery is pretty easy so you could try that but it would help if you told us more about the history of the device.
このアンサーは役に立ちましたか?
Thanks for the answer!!
Regarding what happened to the iphone I have to correct the question, the iphone is not mine. The only thing I know is that the screen was broken.Anyway, I already replaced the screen and the battery that was dead !!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 32
