メインコンテンツにスキップ
モデル番号A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5もしくは3.5 GHz Core i7 Processor, ID iMac14,2
232の回答 すべて表示
Planning to repurpose the display, can I repurpose the speakers too?
My 2013 27” iMac has served me well, but is starting to show its age. I’m planning on disassembling it and selling the internals, but intend to keep the chassis and screen to create a DIY external display using a tutorial I found. However, this got me wondering whether or not I could do the same thing with the speakers. Does anyone have any experience with this? Any insight is greatly appreciated!
EDIT: 8/22/18
Adding some of the resources I’ve found for performing this mod with the screen alone. This is not a complete list.
The part number for the 2013 27" iMac display is LM270WQ1, and can have the part number 661-7169 or 661-7885. Models for sale online often have an" (SD) (F1)" after the model number. Displays on eBay list different designations such as (SD) (E3). I obviously won't know which one I have until i open my machine, but this will clearly affect which controller I need, as when I search for LM270WQ1 controller on eBay, various models appear with different designations.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
What kit did you find?
Keep in mind this series uses iDP (eDP) signaling from the LCD display.
による
@danj OK, I uploaded the photos I took. See link on my update. I found it on eBay but will have to search later for the supplier, he had several different ones for iMacs and MBP.
による
@kazoodac
there is no update.....just post the images to your question. Use this guide iFixitでの質問に画像を追加する方法 for that. What is the exact number from your label on the LCD panel as well as what is it that you want to do with the speakers? You will need some sort of amp to drive them but that will depend on what your want your display to connect to
による
I've updated the original question with some of the resources I've found for this project. This is just as much for my benefit as it is for others who may be looking to attempt this project.
@danj What consequences or road blocks would Display Port signaling have for the mod? The controllers I've seen for this display appear to have HDMI input. Would that cause a conflict?
@mayer The link you posted seems like it's inviting me to collaborate on an incomplete guide. Let me know if I'm missing something. Thanks for posting the photos though!
@oldturkey03 I don't know the exact model number yet, as I haven't fully committed to the project and opened up the computer. However, I do know the display product ID, and added it to the post. A variety of controllers for different designations exist on eBay. As for the speakers, I'd love to keep them in the housing with the display! While I expect having one cable supply both Audio and Video would be too complex, I'd still be thrilled with a separate optical or 3.5mm.
による
@oldturkey03 Did you look at what I used? The PSU and video board come as a kit.
による
表示する 5 他のコメントを
コメントを追加
1回答
最も参考になった回答
I’ve done it on a 24” iMac. You do get a working displayed it’s neat looking but the value is probably about $100.
I wouldn’t even think about it on a 2013 model, which is far more valuable as a working unit.
UPDATE
Here’s the photos I took:
https://www.ifixit.com/Guide/intro/11236...
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
kazoodac さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 187
