I have akai am-m830 no power?
I have just dug out my old akai stack but the amp isnt recieving power checked all the fuses inside and out nothing seem wrong but lights flick on then off what could this be
Most amps and stereo systems have protection against liquid ingress, take the top off and leave it to air out in a room at a reasonable temperature. If it has been in storage it could be condensation on the main board., if so airing it out could fix it.
このアンサーは役に立ちましたか?
I will try this it was thick with dust so i have cleaned it all out hopefully things will change tomorrow cant wait to play some old skool tapes
Excellent, please come back if it works or not, there might be more you can try. Good luck.
Still nothing im going to pull the rest of the decks apart for a thorough clean any thing in particular i should look out for ?
That's a pity. Just check that there is no crud connecting chip pins on the board. If you could also add a picture or 2 of the board I will have a look at it to see if there is anything I can see.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 316
