メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
My iPhone 6 is unresponsive in places. Will a replacement screen help?
Hi, I have an iPhone 6 that I purchased from new, I had the screen replaced over a year ago and it’s always worked fine however recently the device has started to play up (I didn’t drop it or anything). Some parts of the screen still work fine, but other parts don’t respond to any touch at all.
I was wondering if I took it to a local shop to replace the screen, would it help? I have tried everything software-wise, like restoring to factory default etc.
Any help would be greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
What you are describing is indeed most likely a failing screen assembly.
A new screen assembly should resolve this. Provided you have no liquid damage.
Sometimes, you may have board failures that cause similar issues (screen intermittently fails to respond to touch), but first and foremost try a new screen.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Will さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 18
