Mower can sit in the garage for a week with a full tank of gas and not leak a drop but after mowing if I leave gas in the tank that leaked out on the deck
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
1件のコメント:
at the bottom of the carb is a round steel bowl. Inside is a float and needle valve that stops the gas by floating up and holding the needle valve closed. There is dirt in your fuel bowl or the float is full of gas and will not float or the end is off the needle valve. There is a brass nut that unscrews to drop the bowl so you can clean or have a look. Pinch the gas line with locking pliers gently on the hose coming from the tank then have a look. Let us know what you find.
Alton Bell さんによる
