How can I fix it without opening the back?..
My tv is dark all over after i spilt water all over it …..the audio is still working how can I fix it without opening the back?..
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Teddy Mararo you can’t! You at least will have to remove the back from your TV to evaluate the damage. This could be any board as well as the panel. If you let us know what make and model your TV is we can probably help you further, but you will have to remove the back.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 30
2 件のコメント
Its an lg flat
Teddy Mararo さんによる
There should be a couple of numbers with it. Check the label on the back Lg......
oldturkey03 さんによる
