メインコンテンツにスキップ
Troubleshooting and Repair for the 32" 1080P LG 32CS560 LCD TV.
47回答 すべてを表示
Tv keeps turning off.
So I had this TV for the past 4+ years.
Never had any problems til 1 month ago.
The TV keeps turning off after we turn on the tv little “console" that shows the programs and stuff (dont know its name) when its not on the tv works but why have a tv when you cant watch any programs on it?
We already did everything (reset,unplugging and plugging back in,…)
Any way to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I know what you meanly it's the PiP function, while working with external devices, turn PiP to watch TV in smaller window.
This is a good feature; like when you you are using PC, or HDMI, at the same time know what is showing in TV.
I tried this not long ago; the PiP window size can be adjusted!
Unluckily mine can not switch on neither; I used it with my Linux Dongle!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@mikenrafthh
not quite sure what you are referring to with this “after we turn on the tv little “console" that shows the programs and stuff (dont know its name) “ Take some pictures of it and post those with your question. That way we can see what you see. iFixitでの質問に画像を追加する方法
At this time I would disconnect everything from your TV and just use a single input like coax, HDMI or composite. Do not use a cable box or anything. Just things like a DVD player etc. and see if your TV now stays on. If it does not then you may have issues with the power board etc.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mike Nraft さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 394
