メインコンテンツにスキップ
JBLによるFlip ポータブルスピーカー第3世代の修理とサポートガイドです。
70回答 すべてを表示
Only playing through one channel
I noticed over the weekend that my JBL flip 3 is only playing one channel through the speaker. It is really obvious when listening to tracks that panning is quite prevalent. I think the best example is during a guitar solo, only the lead guitar comes through.
I guess the most obvious answer would be that one of the speakers is broken, but I am hoping there is an easier solution.
Any help would be greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
if you can open it up and take out the drivers and test them by going left channel and right channel on the volume
if you find the one that not playing sound remove it and push the cone of the speaker with something and look at the voice coil. if it’s black you might want to replace it with another one. and if its golden of copperish label it just in case you forget and plug it in the other side and test if works if and it does you might want go to best buy and go to geeksquad to ether get it replaced or fixed
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
stubbsbrendan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 148
