メインコンテンツにスキップ
A high end, advanced point-and-shoot camera manufactured by Canon.
24回答 すべてを表示
Camera got wet doesn't power up
I have a Canon SX50 HS or should I say I did have.
Stupidly, I left it out in the rain one night, got distracted by the kids.
Worked ok for a few weeks and then decided to give up the ghost.
Now it will not turn on.
I tried replacing the external battery, no luck.
I read on this site that cameras have an internal battery.
Does the Canon SX50 HS have an internal battery?
This happened a few months ago now and still doesn’t power up. So I suspect it will be dry inside now but some type of damage has been done.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
William Jackson  dry maybe but also corroded. you will have to disassemble Canon PowerShot SX50 HS your camera and clean it properly. Use some 90%+ isopropyl alcohol and a soft brush then clean all the parts with it.
This should help you out aswell
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
William Jackson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 405
