メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
82回答 すべてを表示
Why won't my Ti84 Plus CE turn on?
My calculator will not turn on despite being at full battery (when it charges it has a green light). The screen does not turn on when I press the on button, instead it stays black. I have even bought a replacement battery online, but this did not seem to help. Before, my calculator would often not turn from time to time, but still turned on occasionally, and it always turned on after a few seconds of charging it, but now it does not.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
ベストアンサー
Does your calculator actually turn on but the screen is broken? You can test this out by installing TI Connect CE and connecting your calculator to your computer. If TI Connect CE doesn’t recognize the calculator is connected, I’m sorry, but you’ll have to call TI support and try to get a new calculator.
If TI Connect CE recognizes that a calculator is connected, that means you have a broken screen. Unfortunately, I don’t think you can buy a replacement screen, however if you take the calculator apart, you may be able to finagle the ribbon cable which (in only the best circumstances) may make it work again.
You can try reinstalling the OS, however I don’t believe that would help in this case. If you ever get your calculator working again, you can test if it’s because of defective RAM or ROM by running a self test. You can see how to use it here; read the description for time-stamps and run tests 6 and 7.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
there is a cercuit malfuction when the calculator has reached it recromeened charge it is at its lowest charge till it goes to unstable amps this means you will have to replace the batterys located in the back of the calculator or you will have to get a new one if you are not a electrion if you are then take it apart and put a new circut in it
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
You need to specify exactly which circuit is broken for your answer to make sense. Also, Kingston has already tried replacing the battery.
さんによる
@thelastmill It's one thing for you to downvote an answer you feel isn't very good but to mark these as SPAM is going too far. Moderating an answer or comment as SPAM is for when people are trying to link or sell something unrelated. This is just a poor quality answer (and probably not in the contributors native language). This is not the first time you try to do this.
You offer great answers on all things calculator, let the quality of your answers speak for themselves and stop trying to suppress other people's honest, if not always good, contributions.
I'll add the other mods to this comment to see if they have a differing point of view. @mayer @oldturkey03 @jayeff @danj
さんによる
@refectio - I agree!
さんによる
@refectio the diction of this answer speaks volumes about its quality. It certainly isn't SPAM, just tastes like it.
さんによる
@mayer more like bad oatmeal :>)...
さんによる
2件以上のコメントを表示
コメントを追加
I had this same problem. Green light was on, I believed it had a full charge but nothing. I tried the reset button. I then plugged it into my computer (hoping my computer recognizes my calculator)and at that time I noticed that the mini usb was not inserted fully into the calculator. So, pushed it in a bit more and the light changed from green to orange and it powered up. I read in other troubleshooting forums that the light operates separately from the rest of its calculator bits.
So, maybe it had enough charge to power up the “on” light but not enough for the calculator to charge itself.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kingston Nguyen さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 62
今までの合計 6,477
