Why won’t my ps4 turn on and connect to the tv?
Turns on for 5 sec with 1 beep then turns off with a click. Should I get my money back?
This is a common PS4 defect. You can try giving it a little whack/tap with the palm of your hand or a rubber mallet a few times (not too hard), turning it on its side a few times, unplugging the unit and plugging it back in again. Basically giving it a little jostle. If none of these fix it then you may have to return it. These have worked for some but not all with this same exact problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 113
