メインコンテンツにスキップ
Repair and device guides for the 2016 Samsung Galaxy J5 smartphone, model SM-J510FN.
73回答 すべてを表示
I dropped my phone in the bath and now my data (4G) wont work properly
The question basically sums up my problem, but does anyone know how I fix my data after dropping the phone in water? It still works slightly. I have to have a spectacular connection (full bars) for it to work at all.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@tegan_ricara
if you continue to use it, it will stop to “still works slightly” pretty quickly.  You have a water damaged phone and are running risk to further damage it by using it.
Remove your battery and you’ll need to disassemble your phone. Use something like this guide Samsung Galaxy J5 (2016) Disassembly but it starts at the end of the disassembly. Once you have it disassembled you need to clean it. Use this guide iPhoneの水濡れ・水没ダメージからの復旧方法 for that. It was written for an iPhone but all the points still apply to your phone as well. Once it is properly cleaned you want to go ahead and repalce the battery. Reassemble your phone and then re-evaluate. Only after a proper cleaning can one make teh determination what may have failed. yours appears to be an antenna/RF issue and may require the help of somebody who specializes in board level repair.
iPhoneの画像
ガイド
難易度:
難しい
1 - 2 hours
Samsung Galaxy J5 (2016)の画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tegan Ricara さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 258
