メインコンテンツにスキップ
Nintendo DSiは任天堂 DSラインの第3番目となるモデルです。2008年後期に日本で発売されました。
262回答 すべてを表示
DSi won't turn on, but charging light still seems to work.
I hadn’t used my DSi for many years, and when I decided to power it up again it wouldn’t turn on. The charging light would light up solid orange when plugged in, and would eventually turn off after charging for a while, but still wouldn’t turn on. I decided to look online and figured that the problem was simply a dead battery. I ended up ordering a new one and replaced it, but the problem still wasn’t fixed. I don’t remember it going through any major water damage, but I did drop it quite a few times. Is this problem fixable? Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
use the guideline provided by iFixit to dissassembly ithe DSi and check for all the cables for corrosion or maybe seated improperly.
make sure the screens ribbon cables are fine too, since it is the common cause of dead DSi
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have a problem also, i rhink screws on my dsi are messed up and sht and I am not able to open the battery compartment :(
さんによる
コメントを追加
回答を追加する
Egg さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 34
今までの合計 1,050
