Can not find display panel for UA39EH5003RXZN
Hello,
My display panel is broken for model number UA39EH5003RXZN. It’s 39” LED TV. Can anyone suggest me where can i buy it from?
Thanks in advance.
この質問は役に立ちましたか?
Hello,
Thanks in advance.
この質問は役に立ちましたか?
Typically replacing a panel will cost more than replacing the entire TV. The best way to locate a panel is to use the number off of the panel itself. Remove the back of the TV and look for a label on the panel itself. That will have the model/part number of the panel itself. Sometimes manufacturers use different panels even in the same model of TV. You should verify the panel number first. Take a picture of the label and post it here if you have questions.
Dan
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 105
