メインコンテンツにスキップ
バッテリーのアップグレードやディスプレイの修理を含むSPS Goの完全修理マニュアルです。
89回答 すべてを表示
締切られた回答
My PSPgo don't show a menu "Home"?
I changed the gameboot to another one, and it worked, but after I reset the psp it didn't show anything, it just show the wallpaper without anything like (menu, clock, date,..).
I wish someone tell me how to solve this problem.
Thanks.
About my PSPgo :
- Version : 6.35 , and it's 6.35 PRO-B
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Please someone help me.. please..
さんによる
コメントを追加
4件の回答
最も参考になった回答
It's running custom firmware, so you're in luck. I'm not too familiar with the slims, but you need to download the stock 6.35 update, and boot your PSP into recovery mode. Do this by turning it off, and turning it back on while holding down the right bumper. A menu should come up on the screen. Select "Toggle USB" and connect it to your computer. Now, rename the 6.35 Update that you downloaded "EBOOT.PBP" (if it isn't already named that), and copy it to "/PSP/GAME/RECOVERY/" directory on your PSP's memory stick. Now on the recovery menu, select "Run program at /PSP/GAME/RECOVERY/EBOOT.PBP" Your PSP should procede to reinstall stock 6.35 Firmware. Once the firmware installs, reboot the PSP. It should now be working on stock 6.35 firmware. You can now go back, and reinstall your custom firmware.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
No!! I can't go to Reecovery Mode by using 6.35 PRO-B, and I have PSPgo.
さんによる
can you access the VSH menu? Press "Select" while at the XMB screen.
さんによる
コメントを追加
NO! it's psp go ! so I can't go to Recovery mode by using 6.35 pro-b.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well 6.35 Pro is a LCFW so a Hard reset will return your device back to OFW.
This is done by holding the power button for 10 secs or more. Device will power off. Failing that disconnect the battery [if your careful the warrenty sticker will still be valid]
If you didnt try to perma patch then you should then boot back into the enter settings screen.
If you still have no XMB and you left USB mode to auto connect then see if the device is still allowing for usb mode.
If you have access to a docking station then i have known that to "kick" the device back into being sensible
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
smash your psp
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 3,841
