メインコンテンツにスキップ
2014年9月19日に発売されたこの4.7インチ画面のiPhoneは、iPhone 6 Plusの小型バージョンモデルです。モデル番号はA1549、A1586、A1589で識別できます。
5080回答 すべてを表示
Why is my phone stuck on Searching/No Service?
Yesterday I dropped my phone in water, and I immediately shut it off. I opened it up and dried everything. I turned it on and everything BUT the SIM was working, it had No Service. I then found iPhone thinks there is a sim, when there isn't? and read finster’s comment, number 2 seemed to do the trick. However, today I tried putting another SIM in to see if it would work, and it didn’t. However, now it’s can’t recognize whether a SIM is in the slot or not. I tried finster’s suggestion 2 again but it still doesn’t recognize it. Now it also says it can’t update carrier settings because the other SIM uses another carrier. It says “Cellular Update Failed” Any suggestions? Could this be solved with an antenna replacement? Answers are appreictated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Take it to a reputable phone repair shop for liquid damage evaluation (preferably one that does board-level repairs / microsoldering), the quicker the better to get the phone working properly again from liquid damage.
このアンサーは役に立ちましたか?
スコア 0
コメント:
Can't find a microsoldering repair shop :(
さんによる
Do you have any suspicions as to where the issue is located?
さんによる
It also says "Cellular Update Failed"
さんによる
Sounds like a board level issue as you get carrier update failed. To get that fixed yeah you'll need to take it to someone that does board repair for iPhones.
さんによる
コメントを追加
回答を追加する
p3rs0nn さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 86
