メインコンテンツにスキップ
The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
16回答 すべてを表示
Why is my laptop turn on but not the screen?
at first its wont turn on at all, I opened it, put it back together, now its turn on but not the screen, and once the screen was getting very hot, I have turn it off and power back on again, and the screen still not come on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
connect your system to external display if its working there must be a fault with display, will reply once you execute the step
さんによる
コメントを追加
1 件の回答
If the fan is spinning when you switch on the laptop and no display this could be a problem with the memory. Try taking it out and putting it back and also if you have 2 memory cards try with one. Try connecting to a monitor. If it works on a monitor the problem is with the inverter or LCD cable.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If it does not work with a monitor what could be the problem? fix?
さんによる
コメントを追加
回答を追加する
minh thien さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 426
