メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
369回答 すべてを表示
Loudspeaker hissing and "snow" noise
Repaired a customer’s S7 Edge screen and the loud speaker stopped working. Customer brought phone back when the new part came in and I noticed when it was dropped off that the loudspeaker was making a hissing noise and sounded like snow on a TV. After replacing loudspeaker, the problem did not go away. I had a spare S7 Edge at the shop (as all it does is bootloop), took the loud speaker out of it, and tried the 3rd speaker with customer’s phone- same problem.
Everywhere I look, the answer seems to be software/app related. I looked at the board, and compared it to other boards. No signs of a burn or short or missing chip/bent prong, etc.
So, to recap, his original speaker stopped working after screen replacement. He took the phone with him until parts came in. When he brought it back, the loudspeaker was making a hissing noise. Replaced loudspeaker with new part- still hissing. Tried another part from a different source- same problem.
Any suggestions?
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello,
The only cause I can see is either a software problem, then maybe a factory reset could help, or a component from the motherboard that is causing this problem.
I hope it helped you a bit
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Trevor Brodie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 293
