Why does my lcd work only for a few seconds after switching around lcd
So a while ago a took on the challenge of repairing a broken digitizer on a ipad air 1(Never again), the digitizer was extremely cracked so i ended up carving every piece of glass out as carefully as possible but little did i know i broke the LCD so i ordered a digitizer and LCD and plugged them in and well the LCD didn’t have a back-light, so ordered another LCD did the same thing still no back-light, so i determined after hours of troubleshooting it was a blow filter, i don’t know how to micro solder so i sent it in for repair and i got it back and Great the back-light works but only on the first two LCD’s now this would have been fine but the first is screwed up from me carving glass, and the second one well i made the mistake of thinking the top layer of plastic was a scratch protector and realized i just pulled off the only thing that separates our vision from the back-light, so now i’m down to one LCD to test and when i plug it in it worked for about a millisecond after a hard reset, it only does this after being put in previous to one of the first to LCD’s so it doesn’t work consecutively on the third LCD. So yeah long story short i couldn’t find anything in any forums for such an odd issue. I don’t understand why the LCD works for half a sec and then doesn’t, and also its not the back-light its almost as if the screen just turns off.
p.s if you don’t understand something i said ask me cause i typed this up in about 5 mins.
I have tried the following to fix the problem(other than what i said above)
-Factory reset w/ itunes
-disconnecting everything and reconnecting.
-charge overnight
この質問は役に立ちましたか?
