Repair guides and support for USB flash drives, also known as jump drives or thumb drives.
24の回答 すべて表示
My flash getting hot,when ı plug into my laptop.
I have SanDisk ixpand 32 GB (2 years old) and a brand new SanDisk Ultra Fit 3.0 32 GB USB thumb flash drives.
My problem is, both flash drives are always getting hot when I plug them in and do any file transfer.
  • What can I do to prevent them from overheating ?
  • Is this harmful to them ?
Thanks,
Regards.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Heavy file transfers will cause the drive to get warm. This is normal.
による
コメントを追加
Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3回答
最も参考になった回答
It is normal for a flash drive to get warm duing use. (my sandisk cruizer blade gets quite warm when moving files from it)
この回答は役に立ちましたか?
スコア 5
コメント:
maybe his computer is very hot itself, you know
による
No I had Omen and enough cool .
による
コメントを追加
Run Task Manager to see if there is a lot of drive activity with regard to the USB drives.  (A lot of continual drive activity could cause heat.)  If there isn’t, then the USB port is likely putting out too much power.  I don’t know how that could happen, unless there is a chip in the computer which is bad and which controls power output.
If there is more than one USB port, does the problem happen when you plug the flash drives into a different USB port?
この回答は役に立ちましたか?
スコア 2
コメント:
I will try it but i connect my ixpant to my iphone and same happens .
Thanks,
Best Regards.
による
コメントを追加
Good flash drives will throttle their transfer speeds down to accomodate for heat output from the flash drive itself. Nothing to worry about. I have plenty of flash drives that do this due to heavy file transfers and they are still working till this day so it’s normal.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Berke さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 86
