メインコンテンツにスキップ
The Plantronics CS50 Headset is a wireless digital headset system manufactured and marketed by Plantronics, Inc.
Why can't I hear anything?
My CS50 works perfectly on one phone, but when I move it to another phone, I can't hear anything. It is installed correctly, and when I press the button on the headset, the regular receiver shuts down. But I cannot hear the dial tone through the head set. I haven't changed any of the settings on the base. Am I missing something?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @jf6 ,
Try moving the configurations setting switch on the base unit, through numbers 1-4 to see if you can get dial tone.
Here’s a link to a video that shows what I mean (1:20 minutes into the video)
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you. It still does not work. Very puzzling,
さんによる
Hi @jf6 ,
Being a bit pedantic but the video shows that you press the button on the headset first and then you lift the handset off the phone but you say "when I press the button on the headset, the regular receiver shuts down" which to me indicates that you're doing it the other way around.
I realize that it should transfer from the handset to the headset but am wondering if the sequence has to be in the correct order.
Apologies if this is what you meant.
Is this 2nd phone the same make and model type as the first that you have no trouble with?
さんによる
コメントを追加
回答を追加する
J. Kessler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 703
