iPhone 7 booting loop.. when powering on the device it keeps restartin
iPhone 7 restarting .. when I turn on my phone it shows Apple logo then turns off and then on again .. same happens all the long but never boots up
From what I've seen boot loops are usually indicative of something (usually physical) failing the initial health check. Has anything changed leading up to this - either a drop (ie physical damage) or it being opened up for a repair?
このアンサーは役に立ちましたか?
Yes actually I had my iPhone being up opened up and changed the back body panel .. but when I got it assembled back it only keeps restarting..
このアンサーは役に立ちましたか?
This could be a damaged component or a bad connection. If everything was detached from the logic board and then re-attached it could be a lot of things.
You could try detaching the front flex and then trying to boot - just to rule it out... but you can't do that with all of the components. Maybe the best thing would be to take the board back out and put it back in (i.e. re-seating everything)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 43
