メインコンテンツにスキップ
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
111の回答 すべて表示
MacBook Air with jumbled up directory
A couple of months back, a friend of mine has purchased a mac air (13, 2017). Suddenly he was unable to see a drive icon when an external disk was attached in on the left side usb port and thought the port had a problem. Actually, when I looked at the system I found the directory structure was completely jumbled up. The main folders (Document, Download, Macintosh HD etc) were distributed here and there and did not even show up in the Finder. But they are all there. Would it be possible to get back the correct directory structure by reloading OSX? The user directories may be moved to different disk and reloaded into the system after directory repair. I forgot to mention the system OS is High Sierra. Any suggestion with be highly appreciated. Thanks a lot.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
選択されたソリューション
Use Recovery Mode
  1. Shut down your Mac.
  2. Press the Power button (the button marked with a O with a 1 through it)
  3. Immediately press the command (cloverleaf) key and R together.
  4. Make sure you're connected to the internet through Wi-Fi. ...
  5. Select Install Mac OS X, then click Continue.
  6. Wait.
この回答は役に立ちましたか?
スコア 2
コメント:
Thank you so much. I thought it that way. But wanted to have a word from an expert before going ahead with it.
による
コメントを追加
回答を追加する
Durga Mahapatra さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 14
