メインコンテンツにスキップ
An 18.4" table top tablet with a built-in kickstand and handle, designed for high-quality video and media streaming.
35回答 すべてを表示
My Samsung Galaxy View won't charge. What can I do?
Hi. My Samsung Galaxy View won't charge. I checked for dust and/or lint but there isn't any. The A/C adapter, the end of it, is loose. It wiggles around a lot and I think that's part of the reason why it won't charge.
Also, the device is dead. May someone help me fix it without taking the device apart? Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
Its possible that the adapter is faulty and needs reacing
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What's reacing?
さんによる
I got new charger
さんによる
コメントを追加
I also have the same issue with mine for about 2 months.
I notice that even though the “male” connector appears unbroken, bent or otherwise damaged, I do suspect the “barrel” power port in the body of the tablet may have cracked or become loose.
I have 2 power supplies (one for home, one for on-the-road), and both demonstrate the same failure.
IF I am careful, I can put the power jack into the connector, but play around with it until I see the power connected icon come on at the top right corner of the screen. (It may take a second, so be patient)
What I do is wrap the power cable under the base (as a weight) to keep tension on the power plug (when the charge light comes on) to keep the connection flowing. I am able to recharge the battery to 100% using this method, but it is a pain to fiddle-fart around with all the time. I’m talking only about a couple grams of tension, not, like, 10 lbs LOL.
Hence why I’m here - to find out how top open the back up and repair/replace the barrel jack (which I’m positive is the issue here - or possible a loose connection to the barrel jack).
So, who knows how to open this puppy up for “minor” repairs (but critical for my brain!).
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Sadly my tablet is dead, so I can't easily check if it's charging or not.
さんによる
two screws inback of unit.. then use guitar pick or simular its all click into place ,,, easy to open once you get it going suggest start top center
さんによる
IF You can find the internal power receiver - it's a tiny square module about 5mm x 3mm, you just "unplug" the old one and plug the new one in.
The issue is trying to find the stupid part. I remember my last repair, it cost me about $3.99 (+S&H), so it's not an expensive item. Just hard to find!
さんによる
コメントを追加
Several videos on YouTube.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
PS- Company in EU carries the charger port for about 12 bucks +. You'd have to open the case. Looks Iike Plug + Play. I'llbe finding out.
さんによる
can you give me the link for that EU company that has those charging ports at 12.00?
さんによる
コメントを追加
回答を追加する
Affan Zaman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 46
今までの合計 4,567
