メインコンテンツにスキップ
The Kenmore Direct Drive is a washing machine by Kenmore.
58回答 すべてを表示
Why is my washer taking more than 2 hours to cycle
My Kenmore top load washer seems to do all the cycle steps, but takes more than 2 hours to do so. I had a technician come. No fault on the diagnostic test. He ran the automatic mode and that went fine. Then he did the calibration and found nothing wrong with the machine. But still no change after his visit.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I’d clean the filters. Then watch to see if it is running to long on a particular cycle. Make sure the water flow is strong when starting up (if not, it may be have a clogged screen in the water inlets.
It could also be a failing timer.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks sir for your response. Could you help me locate these filters? And if it is a timer problem, where can I locate it as well.
さんによる
not without the exact model number.
さんによる
コメントを追加
回答を追加する
DENIS BRASSARD さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 2,240
