メインコンテンツにスキップ
様々なテレビブランドとスタイルの修理ガイドならびにサポート
9024回答 すべてを表示
Hitachi Plasma TV 42PD9500TA - Not turning on
Need help getting my Hitachi Plasma TV running again. Currently when plugged in the standby light is red (as normal). When the power button is pushed the light changes to green and the TV sounds like it is turning on, but after 1-2 seconds the green light changes back to red and the TV sounds like it is turning off. Nothing appears on screen during this time.
TV model is 42PD9500TA. Any help much appreciated!
Photos added of back, hopefully helps with reviewing current status:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hey I have the same issue, however I let it do that for a hot minute. At times I may need to turn the TV off and pull the round cord from the box and put it back in. If I let it sit for a long time it is hard to start. It's kinda like a cold two stroke motor, you gotta take power away then dump it back in and let it set. It's probably not healthy for it, however it is over 10 years old, or at least close to. Hope that helped
さんによる
コメントを追加
3件の回答
最も参考になった回答
@csew004 start off by checking your TV with the PDP panel self-diagnosis function
This function is for a PDP panel failure with no picture.
To enter to this Self-Diagnosis mode, follow the next steps:
Preparation:
1) The Power Cord should be connected to AC line and the Main Power switch should be turned on.
2) Turn the power off by the SUB-POWER button of the monitor or the remote control.
Procedure:
1) Press the SUB-POWER button and ▼ button on the bottom of the monitor at the same time, and keep it for more than 5 seconds after the power turned on.
2) It generates red blinking series of the power indicator light.
3) Any operation would cancel the Self -Diagnosis mode.
4) The next table shows the PDP PWB in which failure most probably would be allocated according to the number of blinks.
Number of red blinks of power indication light ==> Presumed failing PWB of PDP panel
1==> Logic
2==> X-SUS
3==> Y-SUS, SDM SDM: Scan Driver Module
4==> X-SUS, Y-SUS, SDM, PSU PSU: Power Supply Unit
5==> ABUS, ADM, PSU ADM: Address Driver Module
6==> ADM temperature
7==> ADM temperature
8==> All of above-mentioned PWB’s
Let us know what you get with the test
Update (07/26/2018)
Time to open up your TV and start with some basic testing.
While you are working on your TV, take some good pictures of your boards etc. Post those with your question. Use this guide iFixitでの質問に画像を追加する方法 for that. It will allow us to see what you see.
Let us know what you find.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Hi, tried to follow these instructions but same result as before, sounds like it will turn on but then turns off. Unable to enter the self diagnosis function. I pushed the power on/off button at the same time as (down arrow) button, trying this on monitor and remote. Unsure if sub power button is different from power button? Not familiar with a sub power button.
さんによる
same button ;-)
this sounds like a power board issue.
さんによる
Hi, I've added some photos of the back of the TV, if you can help that would be much appreciated!
さんによる
@csew004
have you measured the voltages as outlined in the diagram
さんによる
コメントを追加
Since this shuts down this quickly, there is a power problem detected and the set enters safety shutdown. Since this set is likely over 5 years old, I would open it up and take a look at the power board. I have seen many plasma sets that fail in this manner due to defective capacitors on the power supply board. These have deteriorated over time, but finally failed enough to cause this problem. If you area unsure, open up the back and take some photos of the boards and post them here. We'll take a look and perhaps point out the bad parts.
Dan
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Photos added to original question, any help much appreciated!
さんによる
コメントを追加
Have you tried changing the batteries in the remote!
Sounds silly I know but I've had this problem and it was because the remote was giving out a constant single and was turning the TV off. I changed the batteries and it worked fine
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Chris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 8,485
