Why won’t my truck crank?
We have replaced computer, fuel pump and filter and oil sending unit and rebuilt distributor. Cleans battery terminals and checked all wires. Firing at all plugs. Will turn over but not crank. Can spray ether into throttle body and it will crank and run fine. HELP
What motor are you running?
mayer さんによる
@mhunter24 besides the enigne size, what exact year and model is this? What have you checked?
Will turn over but not crank. So it turns over but does not fire?
oldturkey03 さんによる
92 Chevy z71. 5.7 engine
Michelle Hunter さんによる
The injectors are not pulsating. They will spray for a second or two then stop. Engine will not crank. Fuel pump should be pumping 9-13. It is pumping 9. This is a brand new fuel pump with new filter
@mhunter24 "Engine will not crank." not crank as in not turning over or just not firing? there is a big difference.....
oldturkey03 さんによる
3件以上のコメントを表示
