I’m not getting sound when movie plays
I get sound until the movie starts then there’s no sound
One thing you want to check for, is where you plugged in your cable into the tv. if its the three little circle lookin ones, your gonna wanna match the colors, although, sometimes, not all the colors will match, and you will have to mix them. but definitely check your movie settings. also, make sure your not connected to any speaker.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 26
今までの合計 2,711
You will need to check the sound options available on that Blu-Ray disc (these will normally be Dolby Digital or DTS). If they are in a different sound format, then your Home Cinema may not be able to process one of the formats. You will need to go into the menu on the Blu-Ray unit and change the digital audio output for that format from Bitstream to PCM. Also check the HDMI cable test it with another cable. If the cable it gets bent or pulled might damage one of the pins. Usually it's the cable goes bad.
Harley Middleton さんによる
hi I just want to thank you guys I've just bought a second hand bluray player and it was only playing sound on some bluray films and not on others and ive just read youre help trouble shooting list about turning the settings to pcm and i didnt think anything would work and that my player might be broken and I've just turned all the 3 pcm settings all on and I can't believe it I now have sound and I cam watch my blurays and thanks a lot andy
Andrew Canter さんによる
THANK YOU! Changing from Bitstream to PCM solved my problem!
Ashley Michalosky さんによる
