メインコンテンツにスキップ
500 series DSLR camera developed by Nikon. Released in February, 2011.
20回答 すべてを表示
doesn't fully shut off (coolpix b500)
hi,
so my Coolpix b500 (they didn't have that in option) isn't shutting off properly, when i shut it off the green light still is on and the battery's die soo fast! (I use lithium) I have check every setting and have looked on the internet but I cant figure out how to fix it!
please help!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Where is the solution to this problem?
さんによる
コメントを追加
1 件の回答
ベストアンサー
I have this issue too. What I do is turn it off, put the lens cap on then turn it on. A message will come on the screen to turn it off then on again. Once I turn it off this time the light goes out. Hope this helps
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I have done this before but wasn't sure if it was okay for camera and if it fully shut off, thanks!
さんによる
Thanks Karen. I was having the same problem but your solution fixed it. Thanks again.
さんによる
Well done…troubled me for ages…works! Thank you..
さんによる
This method seems stupid to me. To use an error action to make the light go out. What does Nikon say to do to get the green light to go out when you shut the camera off. That should do it on the B500.
さんによる
コメントを追加
回答を追加する
heusscarolyn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 11
今までの合計 1,795
