メインコンテンツにスキップ
The Ford Escape is a compact crossover vehicle sold by Ford, an American automaker, since 2000. Ford Escape vehicles are five-door SUVs and are either four-wheel drive or front-wheel-drive cars with front-engines.
167回答 すべてを表示
2013 Escape Randomly Not Starting. Battery & Alternator are good.
Our car will randomly not start or will die while driving. We have a brand new battery and have had the alternator checked and that checked out fine. I'm thinking PCM but not too sure. When inside the car and it won't start, all doors will lock and over head lights flicker really fast. Sometimes the radio and dashboard will light up but the car still won't start. We have tried jump starting several times and nothing. It does this all the time and then it will make us liars and start up just fine. Idk what is going on and it seems like Ford acknowledges the issue but won't put out a recall. Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
My wire harness from the transmission was getting loose because the little nubs that the harness grabs to pullitself tight when you pull the lever down on the harness were some how sheared off so the harness v woul just wiggle off and my range sensor would shuffle .parking aid failure ,and when I turned it off it would still show car was in drive so when I tried to start it it would not start and say transmission not in park.it would show it in drive
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ash さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 45
