メインコンテンツにスキップ
モデル:CUH-ZCT1は、2013年11月にSony Computer Entertainmentから発売されました。このコントローラはSix-axis、3.7 Vリチウムイオンバッテリーを採用しており、修理は複雑ではありません。
387回答 すべてを表示
How do I fix my controller stuck on G on keyboard?
So basically I got this pre owned controller and when I go to type it glitches and stays on the G button, no matter what I do. I tested out the controller in-game and again, it spams certain inputs. I have bought a cheap wired controller and it appears that the problem was the touchpad AND the L3 and R3 buttons. So my question is how do I fix this and is there an option rather than purchasing a controller. Also is there a way to plug a headphone jack into the PS4 if there is no way to fix.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
4件の回答
最も参考になった回答
Repairing the controller in this case sounds impractical. I would just buy a new controller.
There is a reset button on the back of the PS4 controller you could try.
There is no way to connect headphones to a PS4 directly, only through the controller.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
you can absolutely plug a mic and headphone in the usb plug of your ps4 and a adapter that you plug them in , thats i plug my headset with my mic
さんによる
コメントを追加
i think you have to get your controller fixed or try to fix it your self and you would have to open the whole controller
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Restarting the PS4 usually fixes this issue, as rebooting any device fixes most issues. Do note that the bug will reappear after a while. I have this same exact issue with a controller I brought a month ago and restarting the device is the cheap way to do it. If that doesn’t work, reset the PS4 controller, which is a small button underneath the L2 button. You might need a paperclip or a mechanical pencil to press this button.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I did all of this and none of it worked. I tried forgetting and reconnecting the controller restating the game and updating it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josef Baydemir さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 105
今までの合計 11,665
