メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
Suction cup won't adhere
Got my iFixit repair kit to fix a cracked digitizer on an iPad Mini 2. Instructions said to cover the screen in packing tape, but the suction cup provided does not adhere to packing tape -- not at all. Zero adhesion! So I'm stuck. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The cup will work! The tape you used was not laid down smoothly enough for the cup to grab and/or the tape was textured like duck tape.
Keep in mind you also need to apply heat to the display so the adhesive softens. I would apply the tape mostly in the middle leaving a small margin around the edges so you can get to the area where the display is adhered with a heat gun or iOpener without heating the tape directly as well as make sure I don’t create to many wrinkles in the tape for the better suction. Work on one side at a time and use the picks and/or cards to help hold the glass from re-adhering going in a clockwise direction.
To help in getting the cup to adhere you can apply a bit of petroleum jelly to the cup to help improve the seal. You’ll want to fully clean the cup afterwards as applying it directly to glass will leave a good mark which will be hard to clean off.
Don’t forget to wear safety glasses!!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brian Tate さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 147
