メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
557の回答 すべてを表示
Trackpad cursor moving around on its own and clicking anywhere
Hello.
I own a Macbook Pro Late 2011 model and recently the trackpads cursor is behaving weirdly, like it moves around on its own, it clicks anywhere.
I am guessing I need to change my trackpad ?
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Will the trackpad on above link help me ? Do I need to check model number A1278 ?
or just 'Mid-2009--Mid-2012' is good enough to assume it will work with my laptop.
Thank you
Update (07/16/2018)
even the vertical page scrolling sometimes does not work
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpadの画像
製品
$89.99
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
the cursor erratic behavior seems to have stopped today but the 2 finger scrolling is not smooth, sometimes I can not scroll.
and then it works smoothly.
Using the coconutbattery app I found out that MBP battery had 1643 cycle count.
さんによる
Sounds like you have two problems here! A battery which also needs to be replaced. As you can see here you've exceeded its lifespan! Determine battery cycle count for Mac notebooks
さんによる
コメントを追加
2件の回答
最も参考になった回答
Before buying a new trackpad I'd open the Mac and make sure the battery is not swollen. A defective battery might push on trackpad and cause the symptoms you're experiencing.
この回答は役に立ちましたか?
スコア 2
コメント:
さんによる
I checked with a vendor. The battery does not seem to be swollen.
Can't we figure out if the battery is swollen without opening the mac ?
さんによる
No, not possible, it needs visual inspection. You just need a small philips screwdriver to open the bottom, your fingers to unplug the battery connector, and a tri-winged screwdriver to remove the two battery screws. It just takes 10mins to do all.
さんによる
コメントを追加
The part you need is part number 922-9063 which is what the link you have is, you’re good to go!
Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 13" Unibody Late 2011トラックパッドの交換
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jiten shah さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 415
