メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
369回答 すべてを表示
Very laggy and overheats, even after reset.
So I know this is a long shot, and I probably will need to just chuck it at a wall and buy a new phone, but this phone is very laggy (unusable, takes minutes to even type, and apps never load) and it overheats very badly. I measured the battery temperature at 130 degrees Fahrenheit just at its home screen with no apps or services running. I know replacement batteries are inexpensive, but I am beginning to think that it is the processor. No point in replacing anything if the processor is shot.
What does the ifixit community think I should do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The overheating problems often come from the battery, so what you might want to do at first is to try and change it, luckily for you batteries are not that expensive when you consider the average price of phone parts, so you could just order one and replace it to see if it changes anything (for example there are S7 Edge batteries on http://www.cpix.fr/store).
There is also a small chance that it comes from your motherboard, or that the heat has damaged it, in this case there is unfortunately not much to do
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for the suggestion, I think I'm going to get a new battery, and hold-out until the Note 9.
さんによる
コメントを追加
回答を追加する
Alec さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 70
