Son put SD card in Slot drive. It disappeared. What to do?
How can i get it out without service call
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Two things come to mind. First use a thin flat stick and put double sided tape on it and try to fish it out. Second you remove the drive and take its cover off to remove the SD card. Good luck. Ralph
このアンサーは役に立ちましたか?
is removing the drive a big task?
I'm including a teardown of an iMac. It may not be the same model as yours but should give you an idea of whats involved. You know your abilities best. Good luck. Ralph
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 760
