My Nikon B500 won't turn on!
My Nikon b500 won't turn on. The lens moves 1mm out when I press the "on/off" button, I have had the camera for about 4 months and it was working fine but now this? the screen doesn't even turn on. I paid so much money for this. The Lens moves a tad but the screen doesn't turn on.
3 件のコメント
Yes, my camera is rather old already, having been purchased around 2013. But it’s been very well taken care of - spending 95% of its life in a protective camera bag. I also avoided wet environments, and purchased a waterproof Olympus for those times I’m around water. Around 3 months ago, my Nikon started giving me grief but prematurely shutting off or not even turning on. I thought it was a battery charge issue but that wasn’t it. I also checked the firmware, and have the latest 1.1 that Nikon supplies. I then went into the Menu and shut off the Charge by Camera option as I only want this run while using batteries. Still nothing. There is nothing loose when I vigorously shake the camera. It’s a real mind bender as you can’t troubleshoot what you can’t turn on!
brianbbrewster さんによる
I’m scared my camera won’t work and idk what to tell my mom
Your Qxeen Justinâ さんによる
have the same but mine had the viewfinder rubber cover off i guess a drop got in on the top there is a hole which i discovered after I opened lt with the 2 rear ribbons disconected it turn on the lens went back in and was charging ok . So how can I check the rear part.
josesalgado74 さんによる
