メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
iPhone 7 NFC(Apple Pay) not working after battery replacement
I recently changed my iPhone 7 battery with ifixit replacement battery that is being sold in the store, and NFC (Apple Pay) doesn’t work on any terminal ever since the replacement. Everything else works totally fine with my phone with better battery life but I cannot use Apple Pay to pay at any store or vending machine. What should I do to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
5件の回答
最も参考になった回答
I replaced my screen on an iPhone 7 and afterwards apple pay would not work (I got no response from the phone when I held it up to a contactless payment terminal). I tried another screen with no luck and thought I had damaged something. But when I tried yet another screen I noticed something in the repair process.
At the top right of the phone ( when you are looking at it from the front but with the screen removed) there is a connector for the front facing camera. This connector has a small metal plate over it to keep the connector in place. This plate is secured by two small screws. The screw that is closest to the edge of the phone actually screws into another screw.
That lower screw has a hollow centre that is tapped to accept the screw that holds the metal plate in place. But I noticed it had come a bit lose. It needs to be tightened with a small flat blade screwdriver. I did that then replaced the screen connectors and metal plate and, hey presto, NFC is back in operation.
このアンサーは役に立ちましたか?
スコア 8
5 件のコメント:
THANK YOU so much - this fixed the problem instantly.
さんによる
You guys are the best!
さんによる
Waw. How did you found that! Marvelous! Thank you so much.
さんによる
ditto. the grounding strap the stretched from the top right edge, snakes around the corner, and down to the bracket that covers the screen connector was UNDER the motherboard. I moved it on top and BOOM, in there.
さんによる
Thank you so much for posting this solution! Same thing just happened to me - Apple Pay stopped working on my iPhone 7 after paying Apple (!!!) for a battery replacement at an Apple store... they were going to hot swap the phone for me to 'fix' it, but cracking it open myself and tightening that one socketed screw fixed the problem!
さんによる
コメントを追加
Sounds like the NFC tag at the back of the phone housing got damaged during the battery replacement.
As far as I know this is located between the metal housing and the backglass meaning it would require changing the housing to fix this if it's damaged. It could be something as simple as a loose connection for NFC cable but I could be wrong.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Could also be the NFC bracket near the RCAM. Perhaps the OP removed that screw as well when removing the bracket.
さんによる
Thank you for the comment. What do you mean by the OP?
さんによる
Check out this previous question:
Replacement NFC antenna (Apple Pay not working))
さんによる
コメントを追加
For an iPhone 7 (4.7 inch) model, something that is NOT in the teardown guide is that this little part is the NFC antenna.
I accidentally stripped the new housing screw hole during a housing replacement, and after that Apple Pay and NFC stopped working.
After several days of trying to get the Standoff screw to tie, I finally decided to put a small rubber pad on top of the Frontfacing camera shield on the board so it will be pressing down with the Display. Not expecting much, I checked Apple Pay and voilá! it worked!
(Over the screw on the right)
So
TLDR;
Do not damage the Standoff screw or the flex, that’s the NFC antenna. Had to jimmyrig it to work after I blew it.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Just out of curiosity to help understand the fault, can you tell me what iOS you are running? Also where did you buy the battery from, is the battery health option working, we have come across this with low quality batteries, this is why we only buy from an OEM factory.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
these screws must be tight for NFC to work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sang Yang さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 130
今までの合計 29,190
