The key in side the car!
How can i open the door and the key inside the car and i dont have anuther key thank you
Man, you'll probably need to go to a police department, prove that the car is yours by showing the documents and then I think they'll help.
このアンサーは役に立ちましたか?
Generally either this, or if you are in the US many towing services have tools to get into a car.
Yeah, bit people can think you're trying to steal the car
I have had to call Pop-A-Lock before because I have done just this before. I hope you have your phone on you and not in the car but try to contact a company like Pop-A-Lock.
このアンサーは役に立ちましたか?
Ok, thanks for the tip!
The easiest way is to call a specialist.
I had a similar situation with a friend's car. We were about to leave, but he forgot his sunscreen at home and asked us to wait for him in the car. While he was running after him, I decided to smoke. I got out of the car, closed the door. I heard a sound and realized with horror that he had self-closing doors on the car.
After a few minutes of swearing, he still agreed to choose a locksmith, and I called the specialists from https://www.locksmithsingapore.sg/. The guys arrived quickly and did the work efficiently.
But my friend hasn't left me in the car since then.
このアンサーは役に立ちましたか?
Either you brake the smallest window, or u have to try to put a screw driver between the door and the body and try to open a small way for anything hard and tall to reach the unlock bottom
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 7
今までの合計 96
