メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
320回答 すべてを表示
Is the screen dimming software or hardware related?
When I close the lid of my screen and re-open it: the backlight is off but I can still see the LCD image. If I close the lid a few times and reopen I will then be able to see the screen with backlight on (normal).
So initially I was like ok great, probably the inverter cable getting pinched in the hinge.
But then when the backlight is off and I navigate to the apple symbol and click sleep and wait a second and then press spacebar (or any key) the screen wakes to normal (from no backlight). So now I start thinking maybe this is software related?
I reset the SMC, problem still persists.
I'm also wondering: is there some sort of switch in the hinge that is getting stuck? If so, what does that look like and how could I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Your system uses a magnet in the lid and a Hall sensor in the uppercase. The easiest way to locate it is to use a steel paperclip to locate the switch magnet along the left side, then carefully fold the display down to give you a reference on the uppercase use a small magnet to fire off the Hall sensor.
Given how new the system is you’re likely covered under warranty.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
nullbert さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 63
