メインコンテンツにスキップ
A collection of guides and support to help with washer repair.
3471回答 すべてを表示
Only drains after power rest and leaving lid open
GE Washer
GTW460ASJ0WW
When I start a normal cycle the washer runs normally until it gets to drain and spin part of the cycle. It makes a low 'hum' noise and eventually stops.
If I unplug the washer for about 30 seconds, plug it back in, leave the lid open the washer drains on its own after about an hour (I think, could be hours). So the pump seems to work but its refusing to work properly during normal operation.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Your conclusion that the drain pump works is not substantiated by your statement that it takes an hour to drain. Rather it shows that the pump is not working and the drain may be partially clogged. Here are the things you need to look at:
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
When I lay the drain hose on the ground it flows quite freely. It doesn't only drain after being left for a while but also the first attempt at running a cycle afterwards. Any subsequent cycles however do not drain.
さんによる
OK if is draining when disconnected look further down the line. You may need to snake drain pipe.
さんによる
コメントを追加
回答を追加する
Nick Coffin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 1,318
