メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2686回答 すべてを表示
Why do I have bad signal with an iFixit Lightning Connector
Hi!
I went through iFixit to avoid having the problem that was reported with using non-genuine parts or knockoffs through amazon of having weak or no cell signal with the antenna.
After installing the iFixit kit, I'm having the issue that I thought buying iFixit's more expensive part wouldn't cause. In places I used to get moderate 4G signal I'm down to 3G and in places where I used to get weak signal I have no signal at all. I can still get 4G in some places but it's rare now.
Is there something that I could have botched up in the phone or do I just need to return and get a new part from iFixit.
Thank you,
Denton
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
It may not be the lightning connector, since the Cellular Antenna is located on the top portion of the phone which must be disconnected to get to the bottom part of the device. You may want to look at that section and see if the connectors are damaged or if you put the screws in the wrong place.
Step 29-33 for reference
Reinspect your work and let us know. Good Luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My bad I just realised I put the iPhone 6s as my model. It's just the basic 6.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'm pretty sure the antenna is also located in the lightning port flex cable. If after some troubleshooting you think the Lightinng connector flex cable is to blame, you can contact iFixit and ask for a new one under their warranty.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Denton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 45
