2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
492の回答 すべて表示
The display has stopped working, and the power is cutting out.
The display stopped working one day. It went through some stages of flicking back on for a period of time, but irregularly not working when I went to use it. There seemed to be no cause or fix to symptoms. The screen still registered touches to input the passcode and use the shutter, etc.
After about 3 days of these symptoms, the display stopped working and never turned back on.
I bought a replacement screen and did the job myself, with no improvement.
At this stage I took it to a repair shop, where I suspect they simply did exactly what I did but I was told that it was not repairable and completely unresponsive. I turned it on and commanded Siri to call somebody to show that the phone was still operational.
There were sounds from the phone indicating that I could enter my passcode, click the shutter button and open apps etc.
I have now noticed that the power has begun to cut out and the power cycles if on charge. It simply turns off if not on charge.
Could anyone please give me some advice on what I can try to do?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
I believe your phone has more than one issue from your description..are you the first and only owner of this phone ? Did it get hit bad by a fall or was it liquid damaged ?
による
It has had one somewhat hard contact fall long before symptoms presented, otherwise it was protected well.
による
コメントを追加
1回答
選択されたソリューション
I believe your iPhone has a failed display circuit, or failed backlight circuit.
Both are usually repairable by someone who can perform microsoldering repairs.
Find someone - reputed - who does and take it to them or mail it to them.
We do them all they, they are usually pretty straightforward unless there is (extensive) water damage inside.
この回答は役に立ちましたか?
スコア 2
コメント:
Thank you for your input.
による
コメントを追加
回答を追加する
Sebastian Lukoszek さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 20
