Where I can buy ink absorber pads for Canon PIXMA G3400?
Hello!
Or I can clean it myself?
This has a howto video, but the program they use to reset the absorber looks like a service technician app, which might be a problem.
このアンサーは役に立ちましたか?
You can clean them yourself. I’ve done it on my G3400. Unscrew and remove the back panel. At the bottom on the left inside the printer are 3 pads layered on top of one another. The first one is folded in half. Remove them carefully, making note of the order and orientation for replacement. Soak them clean in alcohol, thoroughly dry and then replace in reverse order. Reset the printer with instructions in the link.
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 9
過去 30 日: 38
今までの合計 7,383
2 件のコメント
I cleaned them myself.....had to disassemble the whole printer to get out and wash the ink tank pads. I would prefer to get new ones!
budgielind さんによる
I would really appreciate an answer to the original question - Where I can buy ink absorber pads for Canon PIXMA MG5350?
Allan Carpenter さんによる
