メインコンテンツにスキップ
Sony Xperia Xは2016年5月に発売されました。シングルタイプのSIMかデュアルタイプのSIMが選べます。5.0インチサイズでこのモデルは1080 x 1920ピクセル解像度です。Android OS, v6.0.1。容量は32/64 GB, 3 GB RAMです。
30回答 すべてを表示
Phone Screen not working (no touch)
Hello!
A while back, I dropped my phone in water and immediately disassembled it to dry it off. The symptoms were a screen that either worked perfectly after reboot and then turned black every time the screen was turned on, or a perfectly functional device except that the digitizer did not work. So, after reading some "advice", I soaked my screen in 91% alcohol, leaving permanent marks. Then, I soaked the logic board in alcohol with a vibration assist from a washing machine. The logic board seemed to be fixed, and being a perfectionist, I tried to go a step further by using a food dehydrator to dry the alcohol marks out of the screen. However, after a while of drying (of screen only, vacuum sealed into a container with silica gel and dessicants), the screen digitizer does not work anymore.
My question is this: is the problem with the screen or the logic board? I noticed that some antenna contacts were slightly bent out of shape, but I am not sure what happened to the rest of the board. There doesn't seem to be corrosion. Keep in mind that after the laundry machine vibration, I took the board out of alcohol, but after I discovered the screen issues, I put it in for around 24 hours.
If needed, I can send photos.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
OK, I am actually out of state right now, I will post once I get back. Yes, I will order the replacement screen later.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@froggr123 just add your pictures to the question. Use this guide iFixitでの質問に画像を追加する方法 for that. Going by your description alone it sounds like the issue is with your display assembly. I would go ahead and replace that. If the error is on the motherboard, then there is only a slim chance of repair. You would need a schematic which is not available. Sony simply does not have those anymore. Replace the screen and re-evaluate Sony Xperia X LCDスクリーンの交換
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Sony Xperia X LCD スクリーンの画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
@oldturkey03 I will upload images tomorrow (just got back from out of country). Will order screen later from Amazon. The WitRigs screen does not have a frame, and I don't want to detach the frame for safety reasons. Hopefully the screen is legit. Thanks!
さんによる
コメントを追加
回答を追加する
froggr123 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 205
