メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
People can't hear me when I call them?
My iPhone 5s more often than not fails on first attempt at a call to someone.
Here’s what happens.
I call someone,they answer,I can hear them but they can’t hear me. I hang up and re dial and it’s fine. It doesn't matter whether I'm on the handset, loudspeaker or my BT earphones with mic, it happens with them all.
This started happening around 10months ago. The handset is 25months old.
I’ve tried lots of things,turning off WiFi,resetting phone to factory settings and setting up as new phone., latest iOS...nothing helps. I've been through various iOS updates so don't think it's software.
My carrier sent me out a new SIM card to try and resolve but it's not helped at all.
I have decent signal most of the time when it happens.
Anyone able to help try and pin point issue?
Thinking it could be a hardware issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Hi @fraz1001 try using an earpiece with mic and make a test phone call.
Observe the results and update us :)
さんによる
Should have said, it doesn't matter whether I'm on the handset,loudspeaker or my BT earphones with mic.
The fault occurs on all 3 methods
さんによる
コメントを追加
2件の回答
For your headset not to be working this is either a collaboration of parts that are failing. (Charger port, microphone, front camera flex, etc. . . ) Or you are having motherboard issues. A long shot could be a software problem but that would be a lot harder to determine and fix on an iPhone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try to change the piece that contains the connector, the mic and the speaker in the iPhone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Fraz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 2,598
