メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
591回答 すべてを表示
Help my MacBook becomes hot and then becomes slow
Hey so i bought a Macbook Pro Late 2011 Second hand from a friend of mine and i has been working fine for a long time so one day it started to get a bit slow so I added some ram to it, which solved the problem but now it gets hot and really slow even though I have swapped out the original Apple 500GB HDD with a 256GB Samsung ssd
please help what parts would you guys recommend that I change on it I really like this Macbook and im not prepaired to go and buy a new 2017 model for those ridicoules prices that they are being sold for Pretty please help what do I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Computers need to be cleaned inside every now and then to get back the correct air flow to allow proper cooling. Being a 7 years old Mac it would need to remove fans, logic board and heatsink to clean them up..heatsink might be partially or very clogged by dust. Thermal paste is probably dry after all this time and needs replaced. Summertime temperatures just make things worse. Overheating may damage logic board beyond repair sometimes. I would suggest before anything else to take up this task yourself if you feel like it or just pay a pro to do it for you. In case you decide to do it yourself this guide will help you in the task step by step MacBook Pro 13" Unibody Late 2011の基板の交換
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Drew Iyore さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 190
