メインコンテンツにスキップ
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
56回答 すべてを表示
Vertical lines appear then disappear (I think it's software)
I was examining my laptop whist installing multiple programs and updating drivers. At first the vertical line was going on and off pretty quickly but now It's here to stay (sometimes it goes away)
It randomly goes away without pressing the screen or anything
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Connect an external monitor to the laptop and check what its' display is like.
If there is no line showing on it then it is most probably a hardware problem with the laptop and your installation activity could have been just a coincidence.
If the external monitor also shows a line, try starting the laptop in “safe mode” and check if the line appears.
If it does then again it could be a hardware problem.
If there is no line when in safe mode then it is most likely a driver problem.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Jau Timbol さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 2,607
