メインコンテンツにスキップ
The Epson L200 is an all-in-one color inkjet printer, copier, faxer, and scanner.
14回答 すべてを表示
Didn't filled all Ink colors at the first time
Hello, I just bought a new Epson l310 printer.
in installation program i was asked if all of the ink tubes filled, i clicked yes, but actually i filled just the black color, the printer started to load the ink, it took 20 minutes and all was good with the black color, but when i filled the other colors, i couldn't do the same ink load like in the begining, and now i can't print with colors, what should i do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You may be able to do a factory reset on the printer, that mite bring up that menu choice again. In the settings there also may be a way to add the ink as well. Or you mite just have to do some print head cleanings that should start sucking the ink through.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tal sharara さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 50
