メインコンテンツにスキップ
The Jeep Cherokee is a line of vehicles sold by Jeep under various vehicle classes. Originally sold as a variant of the popular Jeep Wagoneer, the Cherokee has evolved from a full-size SUV to one of the first compact SUVs and eventually into its current incarnation as a crossover SUV.
59回答 すべてを表示
Where is the windshield washer pump located
The pump is not located in the wheel well. Not located in front of the windshield under cover with wipers. Where is it ?????
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
What year is you jeep? Most washer pumps are located on the bottom of the washer fluid reservoir so find the reservoir and look to the very bottom . If its not there then follow the lines that come out till you find the pump it has to be in the lines somewhere . Hope this helps
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Mine was located in the reservoir and the reservoir is located in the driver side wheel well
さんによる
コメントを追加
回答を追加する
Charlie Davis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 558
