I don't remember my pattern. How do I reset?
I have not used my tablet for awhile and don't remember the pattern for security. How do i reset?
If you forgot your pattern, your device probably have secondary option to retrieve or open back your device.
It could be your passcode or email field where to send you a guideline how to retrieve back to your device.
このアンサーは役に立ちましたか?
Thank you, but I can't get anywhere on the tablet without the security pattern. And now I can't even get into the website. I logged in with Google but that's not an option now.
have you reached the maximum input number of your pattern? If you do, there will be a small text below where it will be linked to passcode section.
In case you can't see the passcode text... Please do follow this guideline:
Forgot unlock pattern and recovery email password
Hope it helps you.
If you have forgotten it, you might be able to factory reset it (but you will loose all your content and data) but this will allow you to use it again.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 984
